Введение
If you’re experiencing problems with your screen, consider reading this guide. This guide will show you how to replace the LCD screen in your Canon PowerShot ELPH 330 HS.
Выберете то, что вам нужно
Turn off your camera.
Remove the battery.
Slide the battery door open with the rubber pad on the bottom right side of the camera.
Remove the battery by pushing down on the release button.
Remove the two screws on the bottom of the camera with a Phillips #00 screwdriver.
Flip the camera over so that the lens is facing you.
Disconnect the highlighted port from the motherboard.
