Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement
Выберете то, что вам нужно
  1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: шаг 1, изображение 1 из 2 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: шаг 1, изображение 2 из 2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right to open it.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: шаг 2, изображение 1 из 1
    • Use the Phillips #00 screwdriver to remove the screws.
  3. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: шаг 3, изображение 1 из 1
    • Remove the two 4.0mm screws on the bottom of the camera located near the battery door using a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: шаг 4, изображение 1 из 1
    • At the bottom of the camera next to the battery door, remove two more screws using the Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: шаг 5, изображение 1 из 1
    • To remove the back portion of the camera case, use your fingers to carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: шаг 6, изображение 1 из 2 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: шаг 6, изображение 2 из 2
    • On the motherboard there should be a white port. Using the spudger, disconnect it from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: шаг 7, изображение 1 из 1
    • Follow the green and white wire. There is a gray piece of rubber holding the button into place. Remove it with the spudger.
  8. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: шаг 8, изображение 1 из 1
    • Lift the panel off from the top of the camera with your hands.
Заключение
Michelle Ngo
Участник с: 07/23/19
595 Репутация
Автор 3 руководств
Команда
UW Tacoma, Team S1-G3, Liner Summer 2019 Участник UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 членов
Автор 3 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 521
