Canon PowerShot G1 X Buttons Replacement
Выберете то, что вам нужно
  1. Canon PowerShot G1 X Buttons Replacement, Back Camera Casing: шаг 1, изображение 1 из 2 Canon PowerShot G1 X Buttons Replacement, Back Camera Casing: шаг 1, изображение 2 из 2
    • To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
    • Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
  2. Canon PowerShot G1 X Buttons Replacement: шаг 2, изображение 1 из 1
    • After removing the first screw flip to the bottom side of the camera and unscrew the two screws located toward the back side of the casing. The screw on the front side can be left in. Use a Phillips Head 00 screwdriver for both of these screws.
  3. Canon PowerShot G1 X Buttons Replacement: шаг 3, изображение 1 из 1
    • Now flip to the opposite side of the USB panel screw and unscrew the two screws holding the small speaker cover portion of the camera. Use a Phillips Head 00 screwdriver for both of these screws.
  4. Canon PowerShot G1 X Buttons Replacement: шаг 4, изображение 1 из 1
    • The last screw is located towards the top side of the back of the camera next to the view finder. Unscrew by using a Phillips Head 00 screwdriver.
  5. Canon PowerShot G1 X Buttons Replacement: шаг 5, изображение 1 из 1
    • Remove the side panel covering the speaker by gently pulling it away from the camera. You can also use spudgers to create a lever to help remove the panel.
  6. Canon PowerShot G1 X Buttons Replacement: шаг 6, изображение 1 из 1
    • Remove the back casing by gently pulling. You could also use spudger to create a lever to help pry it off.
  7. Canon PowerShot G1 X Buttons Replacement, Buttons: шаг 7, изображение 1 из 2 Canon PowerShot G1 X Buttons Replacement, Buttons: шаг 7, изображение 2 из 2
    • Remove the two screws above the buttons followed by the screw on the bottom, using a Phillips #00 screwdriver.
  8. Canon PowerShot G1 X Buttons Replacement: шаг 8, изображение 1 из 1
    • Remove the screw on the side of the buttons using a Phillips #00 screwdriver.
  9. Canon PowerShot G1 X Buttons Replacement: шаг 9, изображение 1 из 1
    • Gently remove buttons by hand, once all of the screws holding the buttons in are removed.
Заключение
Benjamin Irvin Bunch
Участник с: 02/20/20
103 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 314
