Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
On the bottom of the camera, push and slide open the battery compartment.
Remove the battery.
Open the screen.
Remove the Phillips #0 screws on the end of the screen.
Remove both Phillips #0 screws on the opposite side of the screen, located near the hinge.
Remove the back panel of the screen, using a spudger or opening tool if necessary.
Turn the screen perpendicular to body of the camera.
Remove the Phillips #0 screw at the base of the hinge.
Push the screen down and away from the camera.
Remove the single Phillips #0 screw at the base of the rotating arm. This will allow you to remove the screen cover.
Remove the black bar attached to the data ribbon cable. You will use this with the replacement.
Slide the black bar from underneath the white socket.
2 участников успешно повторили данное руководство.
2 Комментариев
I'm guessing that the screen is OK and the wiring/connections is the problem.
