Canon PowerShot G3 Zoom Control Spring Replacement
Выберете то, что вам нужно
  1. Canon PowerShot G3 Zoom Control Spring Replacement, Zoom Control Spring: шаг 1, изображение 1 из 1
    • Start by removing all of the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Zoom Control Spring Replacement: шаг 2, изображение 1 из 1
    • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Zoom Control Spring Replacement: шаг 3, изображение 1 из 1
    • Next remove the front and right side panels (the left side is attached to the front panel).
  4. Canon PowerShot G3 Zoom Control Spring Replacement: шаг 4, изображение 1 из 1
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Zoom Control Spring Replacement: шаг 5, изображение 1 из 3 Canon PowerShot G3 Zoom Control Spring Replacement: шаг 5, изображение 2 из 3 Canon PowerShot G3 Zoom Control Spring Replacement: шаг 5, изображение 3 из 3
    • With the top panel removed, locate the metal plate covering the zoom control on the underside of the panel (located on the forward left side, if the panel is oriented similarly to the first image.) This plate will also be connected to some circuit ribbon. Leave the ribbon attached to the plate.
    • Remove the screws from the plate, and lift and fold the plate along the attached circuit ribbon to the right (as shown in third image.)
  6. Canon PowerShot G3 Zoom Control Spring Replacement: шаг 6, изображение 1 из 2 Canon PowerShot G3 Zoom Control Spring Replacement: шаг 6, изображение 2 из 2
    • With the top panel and metal plate removed, locate the zoom control on the underside of the panel (located on the forward left side if the panel is oriented similarly to the first image.) It will be located directly under the metal plate and circuit ribbon that was removed in the previous step.
    • Once the zoom control is located, remove the faulty zoom control spring from the metal pegs on the panel and zoom control.
  7. Canon PowerShot G3 Zoom Control Spring Replacement: шаг 7, изображение 1 из 2 Canon PowerShot G3 Zoom Control Spring Replacement: шаг 7, изображение 2 из 2
    • Replace the zoom control spring with a comparable spring, attaching the loop ends to the same metal pegs to which the previous spring was attached (on the panel and zoom control.)
Заключение
Cory Jeanes
Участник с: 11/07/15
101 Репутация
1 руководство автора
Команда
University of Memphis, Team 3-2, Kim Fall 2015 Участник University of Memphis, Team 3-2, Kim Fall 2015
UM-KIM-F15S3G2
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 17
За всё время: 583
