Canon PowerShot S100 Control Dial Assembly Replacement
Выберете то, что вам нужно
  1. Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: шаг 1, изображение 1 из 3 Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: шаг 1, изображение 2 из 3 Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: шаг 1, изображение 3 из 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Control Dial Assembly Replacement: шаг 2, изображение 1 из 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Control Dial Assembly Replacement: шаг 3, изображение 1 из 3 Canon PowerShot S100 Control Dial Assembly Replacement: шаг 3, изображение 2 из 3 Canon PowerShot S100 Control Dial Assembly Replacement: шаг 3, изображение 3 из 3
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
  4. Canon PowerShot S100 Control Dial Assembly Replacement, Control Dial Assembly: шаг 4, изображение 1 из 1
    • Turn the camera over so that the LCD screen is facing you.
    • Remove the screw (3.9mm, Phillips #00) that is attaching the thin metal frame to the camera.
    • Remove the 2 screws (3.1mm, Phillips #00) that are attaching the control dial panel to the camera.
  5. Canon PowerShot S100 Control Dial Assembly Replacement: шаг 5, изображение 1 из 1
    • Using the tweezers, detach the ribbon cable that is connected to the dial panel.
  6. Canon PowerShot S100 Control Dial Assembly Replacement: шаг 6, изображение 1 из 2 Canon PowerShot S100 Control Dial Assembly Replacement: шаг 6, изображение 2 из 2
    • Turn the camera over so that the lens is facing you.
    • Using the tweezers, gently lift the flap that is securing the ribbon cable to the motherboard.
    • Using the tweezers, remove the ribbon cable from its socket.
  7. Canon PowerShot S100 Control Dial Assembly Replacement: шаг 7, изображение 1 из 1
    • Gently pull the control dial panel, and its attached ribbon cable, through the opening between the top panel and the camera body.
Заключение
Ricky
Участник с: 02/23/15
958 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 1-4, Leahy Winter 2015 Участник USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 членов
Автор 5 руководств
Один комментарий
I have Canon S100 and it was stuck. Can I send this camera to you to get it fixed and if so, what is your address and how much it will cost?
Yeluchuri Paparao - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 11
За всё время: 1,274
