Введение
The control dial on the back of the camera can be removed and replaced.The control dial is used to adjust the camera's settings and navigate the camera menus.
Выберете то, что вам нужно
Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
Turn the camera so that the LCD screen is facing you.
Remove the back panel by pulling it off of the camera.
Turn the camera so that the lens is facing you.
Slowly lift the front panel from the camera.
The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
Remove the rubber guard that rests on top of the lens.
Turn the camera over so that the LCD screen is facing you.
Remove the screw (3.9mm, Phillips #00) that is attaching the thin metal frame to the camera.
Remove the 2 screws (3.1mm, Phillips #00) that are attaching the control dial panel to the camera.
Using the tweezers, detach the ribbon cable that is connected to the dial panel.
Turn the camera over so that the lens is facing you.
Using the tweezers, gently lift the flap that is securing the ribbon cable to the motherboard.
Using the tweezers, remove the ribbon cable from its socket.
Gently pull the control dial panel, and its attached ribbon cable, through the opening between the top panel and the camera body.
Один комментарий
I have Canon S100 and it was stuck. Can I send this camera to you to get it fixed and if so, what is your address and how much it will cost?
