Canon PowerShot S100 Top Panel Replacement
Выберете то, что вам нужно
  1. Canon PowerShot S100 Top Panel Replacement, Outer Case: шаг 1, изображение 1 из 3 Canon PowerShot S100 Top Panel Replacement, Outer Case: шаг 1, изображение 2 из 3 Canon PowerShot S100 Top Panel Replacement, Outer Case: шаг 1, изображение 3 из 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Top Panel Replacement: шаг 2, изображение 1 из 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Top Panel Replacement: шаг 3, изображение 1 из 3 Canon PowerShot S100 Top Panel Replacement: шаг 3, изображение 2 из 3 Canon PowerShot S100 Top Panel Replacement: шаг 3, изображение 3 из 3
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
  4. Canon PowerShot S100 Top Panel Replacement, Top Panel: шаг 4, изображение 1 из 1
    • Turn the camera over on its side so that the terminals are facing you.
    • Remove the screw (3.9mm, Phillips #00) that is connecting the top panel to the metal frame.
  5. Canon PowerShot S100 Top Panel Replacement: шаг 5, изображение 1 из 2 Canon PowerShot S100 Top Panel Replacement: шаг 5, изображение 2 из 2
    • Remove the screw (2.9mm, Phillips #00) that is directly above the camera lens.
  6. Canon PowerShot S100 Top Panel Replacement: шаг 6, изображение 1 из 2 Canon PowerShot S100 Top Panel Replacement: шаг 6, изображение 2 из 2
    • Using the spudger, remove the center ribbon cable that is connecting the top panel to the motherboard.
    • Gently lift the top panel off the camera.
    • Tweezers may also be used to remove the ribbon cable.
Заключение
3 участников успешно повторили данное руководство.
Ricky
Участник с: 02/23/15
958 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 1-4, Leahy Winter 2015 Участник USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 11
За всё время: 2,188
