Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to replace the screen of the Canon PowerShot S230. The guide focuses mainly on the removal of screws and display screen. Fairly simple.
Запчасти
Детали не указаны.
  1. Using a Phillips #0 head screwdriver, remove the screws on the outside casing of the camera.
    • Using a Phillips #0 head screwdriver, remove the screws on the outside casing of the camera.
  2. Use a pry tool to open the outer casing of the camera and access the internal components. Use a pry tool to open the outer casing of the camera and access the internal components. Use a pry tool to open the outer casing of the camera and access the internal components.
    • Use a pry tool to open the outer casing of the camera and access the internal components.
  3. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Remove the metal shield and screws from the bottom interior of the camera. Remove the metal shield and screws from the bottom interior of the camera.
    • Remove the metal shield and screws from the bottom interior of the camera.
  5. Use the Phillips head screwdriver to remove the screws securing the screen.
    • Use the Phillips head screwdriver to remove the screws securing the screen.
  6. Remove the screws on the copper facing from the front part of the camera. Beneath is a connection to the screen. Wiggle this connection to pull it out; it may take some force to do so.
    • Remove the screws on the copper facing from the front part of the camera. Beneath is a connection to the screen. Wiggle this connection to pull it out; it may take some force to do so.
Заключение
Will Appleton
Участник с: 31.05.2016
101 Репутация
1 руководство автора
Команда
Central Coast New Tech High, Team 6-4, Rushing Spring 2016 Участник Central Coast New Tech High, Team 6-4, Rushing Spring 2016
CCNTH-RUSHING-S16S6G4
2 членов
Автор 2 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 129
