Введение
This guide provides instruction for removal of the outer case. This will expose the memory card holder.
Запчасти
Никакие детали не требуются.
  1. Unless otherwise stated,a #00 philips screwdriver will be used to remove screws. Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four 4.75mm screws located on the bottom of the camera.
  2. Remove the two 4.75mm screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the two 4.75mm screws located on the right side of the camera.(the side with the USB adaption plug)
  3. Remove the four 4.75mm screws on the left side of the camera. This will release two small metal plates. Remove these plate. This will release two small metal plates. Remove these plate.
    • Remove the four 4.75mm screws on the left side of the camera.
    • This will release two small metal plates. Remove these plate.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Only remove the back case.
    • Only remove the back case.
    • The memory card is held in the metal case located to the right of the LCD screen.
    • Remove the stuck memory card.
    • If you still cannot remove the stuck memory card, proceed with further instructions. If you could remove the memory card then you are done
  6. There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it. Separate the front casing from the camera
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Separate the front casing from the camera
  7. If the small plastic piece described in the previous step did not fall out, remove it now. The piece is located in a small gap above the lens and to the left of the flash. Removing this piece may require the use of tweezers.
    • If the small plastic piece described in the previous step did not fall out, remove it now. The piece is located in a small gap above the lens and to the left of the flash.
    • Removing this piece may require the use of tweezers.
  8. Locate and remove the three 3.45mm screws on the backside of the camera securing the CF card slot. Do not remove ribbon cable. It is not necessary to remove
    • Locate and remove the three 3.45mm screws on the backside of the camera securing the CF card slot.
    • Do not remove ribbon cable. It is not necessary to remove
    • Without removing the ribbon cable, gently remove the memory card.
Заключение
Adam Grijalva
Участник с: 20.01.2011
202 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 5-19, Amido Winter 2011 Member of Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 3
За всё время: 3,556
