Введение
This guide provides instructions on how to replace the shutter button assembly on the Canon PowerShot S400.
Запчасти
Никакие детали не требуются.
  1. Unless otherwise stated,a #00 philips screwdriver will be used to remove screws. Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Remove the two screws located on the right side of the camera.(the side with the USB adaption plug) Remove the four screws on the left side of the camera. This will release a small metal plate. Remove this plate.
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it. Now separate the front and back camera casings. Now separate the front and back camera casings.
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  5. Using a spudger, carefully pry the shutter button assembly from the camera.
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
Заключение
Ross Bryan
Участник с: 21.01.2011
350 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 5-19, Amido Winter 2011 Member of Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 2,483
