Введение
Did the LCD Screen on your Canon PowerShot S410 stop working so you can no longer see the images you are trying to photograph on the back of your camera?
Follow this step-by-step guide to help repair your LCD screen so you can get back to taking those photos!
Выберете то, что вам нужно
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
Repeat to remove the two 2.3mm screws.
Slide the rubber tab to reveal the bottom screw.
Using the screwdriver, remove the two 3.7mm screws.
Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
Remove the two 3.8mm screws near the strap bracket.
Remove the small panel covering the mounting bracket.
Remove the door covering the memory card.
Remove the 3.8mm screw below the mounting bracket using the Phillips screwdriver.
Grasp the sides of the front cover and carefully pull the front panel off of the camera.
A fingernail or spudger can be used to remove the plastic flap covering the motherboard.
Remove the 2.1mm screw using the Phillips #0 screwdriver
Grab the sides of the bottom panel and lift to expose the ribbon cable.
Using your fingernail, open the black clip holding the ribbon cable.
Gently pull out the ribbon cable in the direction of the cable using your fingers or tweezers.
Remove the two 2.1mm screws on the aluminum tabs of the LCD screen using a screwdriver.
Using a pair of tweezers, carefully pull the top ribbon cable out of the slot.
Grasp the sides of the LCD screen and lift off of the camera.
