Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This installation guide will help you remove your broken LCD and install in a new replacement.
Выберете то, что вам нужно
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
Repeat to remove the two 2.3mm screws.
Slide the rubber tab to reveal the bottom screw.
Using the screwdriver, remove the two 3.7mm screws.
Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
Remove the two 3.8mm screws near the strap bracket.
Remove the small panel covering the mounting bracket.
Remove the door covering the memory card.
Remove the 3.8mm screw below the mounting bracket using the Phillips screwdriver.
Grasp the sides of the front cover and carefully pull the front panel off of the camera.
Remove the plastic flap covering the motherboard.
Using your fingernail, open the black clip holding the ribbon cable.
Grab the ribbon cable and carefully pull it out of slot.
Remove the 2.1mm screw.
Grab the sides of the bottom panel and lift it up to expose the ribbon cable.
Using a pair of tweezers, carefully pull the top ribbon cable out of the slot.
Grasp sides of LCD screen and lift off of camera.
