Введение
Use this guide to remove and/or replace the motherboard on the left side of the camera.
Выберете то, что вам нужно
Place camera LCD side up and press up on the battery door.
Let it swing open until you can see the battery inside.
Press down on the orange plastic.
This will gently eject the battery from its compartment.
Look at the camera from the side with the lanyard and 4 screws.
Remove the two 3.4 mm screws on the metallic colored part.
Place the camera LCD side down.
Remove the two 5.3mm screws by the battery door.
Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
Stand the camera back up.
Remove the two 3.6mm screws on the side with the A/V Out port.
Lift open the rubber flap covering the A/V Out port.
Remove the 3.4mm screw in the center.
There will be a brown plastic piece keeping the thin plastic ribbon in place.
Use the spudger to pull out the brown plastic piece attached to the orange plastic.
Disconnect the black and red cable on the left side of the lens.
Pull off the orange ribbon on the upper left of the motherboard.
Remove the other two orange ribbons on the middle of the left motherboard.
Remove the 3.3mm screw halfway up the left side of the motherboard just to the left of the lens.
Go under the piece of plastic and remove the 2.6mm screw.
Unplug the top part of the left motherboard.
Gently lift the left motherboard up to remove
