Введение
This guide serves to replace a faulty flash mechanism.
Выберете то, что вам нужно
Remove the knot on the wrist lanyard.
Remove the battery and the memory card.
Begin removing the screws on the bottom of the outer casing.
Next, remove the rest of the screws from the outer casing.
Open the "A/V Out Digital" cover. Remove the screw inside.
Gently pull off the back casing.
Remove the black "L" shaped piece of metal.
Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
Unplug the wide ribbon cable.
Unplug the narrow ribbon cable to free the LCD screen from the camera body.
Remove the L-shaped corner trim containing the picture button.
Carefully unplug the connection cable that is attached.
Pull the selector wheel from the top corner of the camera.
Carefully remove the ribbon cable connection with a set of tweezers.
With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
Remove the cable connection. With a metal spudger, gently pry up.
Remove the ribon cable. With a metal spudger, gently lift up the black tab.
