Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide serves to remove and replace the motherboard.
Выберете то, что вам нужно
Remove the knot on the wrist lanyard.
Remove the battery and the memory card.
Begin removing the screws on the bottom of the outer casing.
Next, remove the rest of the screws from the outer casing.
Open the "A/V Out Digital" cover. Remove the screw inside.
Gently pull off the back casing.
Remove the black "L" shaped piece of metal.
Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
Unplug the wide ribbon cable.
Unplug the narrow ribbon cable to free the LCD screen from the camera body.
Gently remove the entire ribbon cable connection to release the ribbon cable from the camera.
Pry up the ribbon cable connection and remove it from the camera.
Lift the ribbon cable tab and completely detach the cable from the camera.
2 участников успешно повторили данное руководство.
