Введение
Use this guide to replace the function buttons on the back of the camera.
Выберете то, что вам нужно
Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
Remove the two screws from the bottom of the camera. (4mm Phillips 00)
Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the top of the function button board.
Slide out the ribbon cable from the connector.
Remove the top screw from the function button board. (3.5mm Phillips 00)
Remove the bottom screw from the function button board. (2.5mm Phillips 00)
