Введение
Removing the LCD screen seems intimidating, but everything comes apart rather easily. You just have to lift tabs, remove a single screw and lift out the screen.
Выберете то, что вам нужно
Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
Remove the two screws from the bottom of the camera. (4mm Phillips 00)
Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
Инструмент, используемый на этом этапе:Tweezers$4.99
Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
Slide out the ribbon cable using fingers or tweezers.
Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
Remove the L shaped brackets from the left and right side of the LCD screen with the spudger tool.
Remove the screw below the shutter button. (2.5mm Phillips 00)
Holding the sides of the LCD screen, lift the screen up and away to remove.
Еще один человек закончил это руководство.
Один комментарий
Hello do you guys sello the LCD screen and do you ship to México.
