Введение
Use this guide to access the motherboard to reseat connections on the motherboard or to remove the motherboard for replacement.
Выберете то, что вам нужно
Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
Remove the two screws from the bottom of the camera. (4mm Phillips 00)
Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
Remove the microphone connector by gripping it with the tool and gently, with a wiggling motion, pull it out.
Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the bottom of the motherboard.
Slide out the ribbon cable.
Use the spudger to pry up each side of the Flat-Topped Connectors
Remove the bottom right screw from the motherboard. (4mm Phillips 00)
Remove top and lower left black screws from the motherboard. (2.5mm Phillips 00)
