Введение
USB Port can be damaged from force exertion on the pins which can prevent it to connect to an external device. This guide will show the steps to replace the USB port in the device.
Выберете то, что вам нужно
Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
Pry the golden ribbon cable attached to the USB port using a plastic opening tool.
Еще один человек закончил это руководство.
