Canon PowerShot SD200 Buttons Replacement
Выберете то, что вам нужно
  1. Canon PowerShot SD200 Buttons Replacement, Battery: шаг 1, изображение 1 из 3 Canon PowerShot SD200 Buttons Replacement, Battery: шаг 1, изображение 2 из 3 Canon PowerShot SD200 Buttons Replacement, Battery: шаг 1, изображение 3 из 3
    • The camera used to create these repair guides had a broken lens assembly. As a result, the lens is sticking out in all of the photos, but it is important to note that this should not be the case with your camera. The lens should retract itself back into the camera when it is turned off.
    • Use your fingernail to slide the dark gray tab located on the bottom of the device towards the edge of camera.
    • Slide the light gray door away from the LCD screen and pull up to open the door.
    • Both battery and memory card should now be visible.
  2. Canon PowerShot SD200 Buttons Replacement: шаг 2, изображение 1 из 2 Canon PowerShot SD200 Buttons Replacement: шаг 2, изображение 2 из 2
    • Rotate the small brown tab towards the edge of the camera.
    • The battery should pop up.
  3. Canon PowerShot SD200 Buttons Replacement: шаг 3, изображение 1 из 1
    • Pull the battery straight out of the battery holder.
    • When putting the battery back in, make sure it is oriented the same as it was before.
  4. Canon PowerShot SD200 Buttons Replacement, Buttons: шаг 4, изображение 1 из 3 Canon PowerShot SD200 Buttons Replacement, Buttons: шаг 4, изображение 2 из 3 Canon PowerShot SD200 Buttons Replacement, Buttons: шаг 4, изображение 3 из 3
    • Close the light gray battery compartment door.
    • Remove the six 2.8 mm Phillips screws on the outside of the case. Two screws are found on each side of the camera, and the final two are found on the bottom.
  5. Canon PowerShot SD200 Buttons Replacement: шаг 5, изображение 1 из 2 Canon PowerShot SD200 Buttons Replacement: шаг 5, изображение 2 из 2
    • Use your fingers to carefully pry off the back casing from the camera assembly.
  6. Canon PowerShot SD200 Buttons Replacement: шаг 6, изображение 1 из 3 Canon PowerShot SD200 Buttons Replacement: шаг 6, изображение 2 из 3 Canon PowerShot SD200 Buttons Replacement: шаг 6, изображение 3 из 3
    • Push the buttons out with your finger if they did not fall out while removing the casing.
    • Pull off the white plastic side piece if it did not fall out while removing the casing.
  7. Canon PowerShot SD200 Buttons Replacement: шаг 7, изображение 1 из 2 Canon PowerShot SD200 Buttons Replacement: шаг 7, изображение 2 из 2
    • Remove the one 2.2 mm Phillips screw from the bottom of the camera.
    • Take off the print button.
  8. Canon PowerShot SD200 Buttons Replacement: шаг 8, изображение 1 из 2 Canon PowerShot SD200 Buttons Replacement: шаг 8, изображение 2 из 2
    • Use your fingers to carefully pry off the front casing of the camera. The front casing should pull straight off.
  9. Canon PowerShot SD200 Buttons Replacement: шаг 9, изображение 1 из 2 Canon PowerShot SD200 Buttons Replacement: шаг 9, изображение 2 из 2
    • Use the flat end of the spudger to lift open the white plastic latch on the front of the camera. Once the latch is lifted up, move the latch up towards the top edge of the camera.
    • Remove the top button assembly by pulling straight up.
Заключение
James Loy
Участник с: 10/06/10
103 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 5-12, Maness Fall 2010 Участник Cal Poly, Team 5-12, Maness Fall 2010
CPSU-MANESS-F10S5G12
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,441
