Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Removing the buttons might be necessary if a button is damaged. This guide will show how to remove all external buttons on the camera.
Выберете то, что вам нужно
Use your fingernail to slide the dark gray tab located on the bottom of the device towards the edge of camera.
Slide the light gray door away from the LCD screen and pull up to open the door.
Rotate the small brown tab towards the edge of the camera.
The battery should pop up.
Remove the six 2.8 mm Phillips screws on the outside of the case. Two screws are found on each side of the camera, and the final two are found on the bottom.
Push the buttons out with your finger if they did not fall out while removing the casing.
Pull off the white plastic side piece if it did not fall out while removing the casing.
Remove the one 2.2 mm Phillips screw from the bottom of the camera.
Take off the print button.
Use your fingers to carefully pry off the front casing of the camera. The front casing should pull straight off.
Use the flat end of the spudger to lift open the white plastic latch on the front of the camera. Once the latch is lifted up, move the latch up towards the top edge of the camera.
Remove the top button assembly by pulling straight up.
