Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
The Canon PowerShot SD200 has an opening for a SD Memory Card. Removing the memory card might be necessary to obtain pictures from the camera. This guide will show how to easily remove the memory card.
  1. Use your fingernail to slide the dark gray tab towards the edge of  the camera. Slide the light gray door away from the LCD screen and pull up to open the door. The battery and the memory card slots should now be visible.
    • Use your fingernail to slide the dark gray tab towards the edge of the camera.
    • Slide the light gray door away from the LCD screen and pull up to open the door.
    • The battery and the memory card slots should now be visible.
  2. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  3. Press down on the memory card.
    • Press down on the memory card.
    • Memory card should pop out of place.
    • Pull the memory card straight out of the slot.
    • When putting the memory card back in, orient the memory card in the same direction when pulling out.
Заключение
Еще один человек закончил это руководство.
James Loy
Участник с: 06.10.2010
103 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 5-12, Maness Fall 2010 Участник Cal Poly, Team 5-12, Maness Fall 2010
CPSU-MANESS-F10S5G12
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,251
