Запчасти
Никакие детали не требуются.
  1. There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws) There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws) There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws)
    • There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws)
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost.
    • Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost.
  4. Open the case gently. The wrist strap plate and disk pieces will fall out during the process.  The second picture shows what wrist strap plate and disk looks like (The circled parts). Replace the broken camera case with the new one.
    • Open the case gently. The wrist strap plate and disk pieces will fall out during the process. The second picture shows what wrist strap plate and disk looks like (The circled parts).
    • Replace the broken camera case with the new one.
Заключение
Yi Huang Ke
Участник с: 18.10.2011
51 Репутация
Автор 4 руководств
Команда
James Madison, Team 1-1, Allen Fall 2011 Member of James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 членов
Автор 4 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 1,717
