Введение
This guide will provide you with step-by-step instructions on how to replace a faulty LCD screen for a Canon PowerShot SD400. The LCD, or liquid crystal display, is a flat monitor that displays images. The LCD may need to be replaced if it has cracks, discolored pixels, spots, blobs, flickering, or if there's no image signal. Before you begin, ensure that the camera is powered off.
Выберете то, что вам нужно
Locate the 6 screws that you must remove to open the camera housing.
There are 2 screws on the bottom and 2 screws on each side
Using the screwdriver, carefully remove the exterior screws and set them aside to avoid misplacing them.
Locate the interior screw to the top right of the screen.
Remove the screw using the screwdriver.
Insert the flat-head screwdriver under the LCD screen into the two clips.
Lift the LCD screen.
2 участников успешно повторили данное руководство.
