Введение
This guide is to assist in the replacement of a malfunctioning or full memory card in your Canon PowerShot SD400 camera.
A memory card is essential for storing photos and videos on your camera. When a memory card is corrupted, failing, or full, your camera could stop saving new media or fail to record.
Before using this guide, ensure that the memory card is the issue by checking for any error messages or by trying to format the memory card after it is inserted in the camera. If you're running out of storage space, upgrading to a memory card with a larger capacity may be the appropriate solution. Check that the memory card that you're using is appropriate for the Canon PowerShot SD400.
Back up any important data from your memory card before formatting the memory card in your Canon PowerShot SD400 to avoid losing any valuable photos or videos.
Push down the memory card and it will pop up.
Remove the memory card from the camera.
