Canon PowerShot SD450 LCD Screen Replacement
Выберете то, что вам нужно
  1. Canon PowerShot SD450 LCD Screen Replacement, Casing: шаг 1, изображение 1 из 1
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
  2. Canon PowerShot SD450 LCD Screen Replacement: шаг 2, изображение 1 из 1
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
  3. Canon PowerShot SD450 LCD Screen Replacement: шаг 3, изображение 1 из 2 Canon PowerShot SD450 LCD Screen Replacement: шаг 3, изображение 2 из 2
    • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  4. Canon PowerShot SD450 LCD Screen Replacement: шаг 4, изображение 1 из 1
    • Take hold of the inside of the camera, and gently pull away from the back casing.
  5. Canon PowerShot SD450 LCD Screen Replacement: шаг 5, изображение 1 из 1
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
  6. Canon PowerShot SD450 LCD Screen Replacement: шаг 6, изображение 1 из 1
    • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
    • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
  7. Canon PowerShot SD450 LCD Screen Replacement, LCD Screen: шаг 7, изображение 1 из 2 Canon PowerShot SD450 LCD Screen Replacement, LCD Screen: шаг 7, изображение 2 из 2
    • Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket.
  8. Canon PowerShot SD450 LCD Screen Replacement: шаг 8, изображение 1 из 1
    • Remove the tripod mount screw.
    • Turn the camera around so that the screen is facing you, and the camera is upright.
  9. Canon PowerShot SD450 LCD Screen Replacement: шаг 9, изображение 1 из 1
    • Remove the screw at the top right of the screen.
  10. Canon PowerShot SD450 LCD Screen Replacement: шаг 10, изображение 1 из 1
    • Lift up the screen to reveal the tripod mount screw.
  11. Canon PowerShot SD450 LCD Screen Replacement: шаг 11, изображение 1 из 1
    • Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
  12. Canon PowerShot SD450 LCD Screen Replacement: шаг 12, изображение 1 из 1
    • Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
    The new screen came without a black light ribbon will it work without it? Canon Powershot sd450
    Mike - Ответить
Заключение
3 участников успешно повторили данное руководство.
Pierre Teplitxky
Участник с: 04/10/10
134 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 25-85, Amido Spring 2010 Участник Cal Poly, Team 25-85, Amido Spring 2010
CPSU-AMIDO-S10S25G85
4 членов
Автор 5 руководств
3 Комментариев
Followed the steps and replaced the broken screen. Now I get only a white screen when turning the camera on. It does take pictures but it won't show anything but a little red dotted arrow on the right hand side over the white screen. Do you have a clue of what is happening?
Roberto - Ответить
Salve, dove posso acquistare un display?
Germano Tinari - Ответить
Salve, sapreste dirmi dove posso acquistare un display?
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 6,564
