Canon PowerShot SD450 Outer Case replacement
Выберете то, что вам нужно
  1. Canon PowerShot SD450 Outer Case replacement, Casing: шаг 1, изображение 1 из 1
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
  2. Canon PowerShot SD450 Outer Case replacement: шаг 2, изображение 1 из 1
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
  3. Canon PowerShot SD450 Outer Case replacement: шаг 3, изображение 1 из 2 Canon PowerShot SD450 Outer Case replacement: шаг 3, изображение 2 из 2
    • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  4. Canon PowerShot SD450 Outer Case replacement: шаг 4, изображение 1 из 1
    • Take hold of the inside of the camera, and gently pull away from the back casing.
  5. Canon PowerShot SD450 Outer Case replacement: шаг 5, изображение 1 из 1
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
  6. Canon PowerShot SD450 Outer Case replacement: шаг 6, изображение 1 из 1
    • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
    • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
Заключение
Еще один человек закончил это руководство.
Curtis Wagner
Участник с: 04/10/10
32 Репутация
1 руководство автора
Команда
Cal Poly, Team 25-85, Amido Spring 2010 Участник Cal Poly, Team 25-85, Amido Spring 2010
CPSU-AMIDO-S10S25G85
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 3,528
