Введение
The image sensor is what actually captures the image when you take a picture. If damaged, the sensor can cause blurred, distorted, or even black pictures.
Выберете то, что вам нужно
Slide open the battery cover.
Push the small orange tab to the side so the battery can be removed.
Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
Remove the internal camera components and layout out all pieces on a clean surface.
Carefully wedge the pry tool under the ribbon in the ribbon gate.
Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
Gently press the ribbon back to get access to a Phillips screw behind it.
Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
Pull the button board away from the rest of the camera.
Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
The LCD can now be completely removed from the camera.
Place the pry tool under ribbon gate and gently lift it up, disconnecting the ribbon.
Unscrew three .15 inch Phillips screws from the back of the camera using a #00 Phillips screwdriver.
Use the pry tool to gently lift the image sensor away from the rest of the camera.
