Введение
This manual is for replacing the function/set button located on the back of the camera.
  1. Using your fingernail, slide the light gray tab towards edge of camera. Slide the light gray door and pull up to open the door. In the camera shown in the photos, there is not a Memory Card or Battery.
    • Using your fingernail, slide the light gray tab towards edge of camera.
    • Slide the light gray door and pull up to open the door.
    • In the camera shown in the photos, there is not a Memory Card or Battery.
    • Both Battery and Memory Card slots should be visible.
  2. Use your fingernail and slide the small brown tab towards the edge of the camera. The battery will pop up.
    • Use your fingernail and slide the small brown tab towards the edge of the camera.
    • The battery will pop up.
    • Pull battery straight out of battery holder.
    • When putting the battery back in, make sure it the battery is oriented so the terminals connect.
  3. Remove the following 4 screws: Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Open the A/V OUT DIGITAL flap on the side of the wrist strap. Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap. Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  6. On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera. Slide light gray door and pull up to open the door.
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  7. Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera. Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  8. Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  9. Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  10. Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo. Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
    • Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
  11. Lift the function set button ribbon cable from the two guide pins.
    • Lift the function set button ribbon cable from the two guide pins.
  12. Remove the ribbon cable by lifting on the flat tab and pulling the ribbon cable from the connection.
    • Remove the ribbon cable by lifting on the flat tab and pulling the ribbon cable from the connection.
Заключение
iDeleted
Участник с: 07.07.2010
2 101 Репутация
Автор 39 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 1,010
