Введение
How to remove the outer casing of your Canon PowerShot SD870 IS.
Инструменты
Запчасти
Детали не указаны.
Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
Remove the screw next to the wrist strap attachment.
Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
Remove the two Phillips #00 screws from the flat end of the camera.
Remove the black L-shaped side cover plate.
Remove the silver u-shaped retainer plate.
2 участников успешно повторили данное руководство.
