Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will take you through the process of replacing a broken screen on a Canon PowerShot SX120 IS.
Выберете то, что вам нужно
Turning the camera so the screen is facing you.
Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
Open the DC IN A/V OUT DIGITAL cover.
Turn the camera with the lens facing down.
Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
Carefully put pressure on the opening tool so the cover can gradually open.
Slowly slide the opening tool along the gap and around the edge of the camera.
Remove the two screws that are attached directly below the screen with a #000 philips screw driver. These screws secure the screen to the main frame of the camera.
Remove the two 3.4 mm screws
Place the camera with the lens facing down. Find the screw that is located on the right side of the camera next to the function set button.
Remove the 3.4mm screw with a #000 Phillips screwdriver.
Leave the camera facing down and locate the ribbon connector. The ribbon connector is placed bellow the main button panel on the bottom right side of the camera.
Lift the main button panel and gently hold the ribbon connector with the black tweezers.
Once the ribbon has been entirely disconnected, lift the entire panel and place it above it's original positions. The panel will not be entirely removed only the lower half.
Use the black tweezers to gently begin to lift the screen. Begin lifting the screen from the left side.
Locate the ribbon connector that is attached to the screen and also the motherboard.
Remove the ribbon from the motherboard connection by flipping up the small black clamp on the connector with a spudger.
Еще один человек закончил это руководство.
