Введение
Disassemble the back cover in order to open the camera and access the inside components.
Запчасти
Никакие детали не требуются.
  1. Remove the double AA batteries before starting to disassemble. This will prevent you from permanently damaging your camera.
    • Remove the double AA batteries before starting to disassemble. This will prevent you from permanently damaging your camera.
    • Turn the camera to the side that has the screen. Unnscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
    • Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
  2. Put the camera with the lens facing up, turn it to the side where the DC IN A/V OUT DIGITAL Cover and lanyard attachment are located.
    • Put the camera with the lens facing up, turn it to the side where the DC IN A/V OUT DIGITAL Cover and lanyard attachment are located.
    • Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver.
  3. Put the camera with the lens facing up, turn it to the side where the Cover battery is located. Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver. Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver.
    • Put the camera with the lens facing up, turn it to the side where the Cover battery is located.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located. Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver.
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  6. Put the camera with the lens facing down, turn it to the side where the DC IN A/V OUT DIGITAL Cover and the silver lanyard attachment are located.
    • Put the camera with the lens facing down, turn it to the side where the DC IN A/V OUT DIGITAL Cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  7. Turn the camera with the lens facing down. Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened. Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully make pressure downwards on the opening tool so the cover can gradually open.
    • Keep making pressure and slowly slide the opening tool through all the gap.
    • There is one point when the cover will disassemble completely.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  8. This is a final picture of how it's going to look when you disassemble the back cover.
    • This is a final picture of how it's going to look when you disassemble the back cover.
    • You will have 3 parts:
    • 1. The camera
    • 2. The DC IN A/V OUT DIGITAL Cover
    • 3. The back cover.
Заключение
2 участников успешно повторили данное руководство.
Maria
Участник с: 13.03.2014
611 Репутация
1 Guide authored
Команда
New Mexico State, Team 1-3, Easley Spring 2014 Member of New Mexico State, Team 1-3, Easley Spring 2014
NMSU-EASLEY-S14S1G3
4 членов
Автор 4 руководств
Один комментарий
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
Frederick Czarnik - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 7
За всё время: 1,087
