Canon PowerShot SX120 IS Back Cover Replacement
Выберете то, что вам нужно
  1. Canon PowerShot SX120 IS Back Cover Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Back Cover Replacement: шаг 2, изображение 1 из 1
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Back Cover Replacement: шаг 3, изображение 1 из 2 Canon PowerShot SX120 IS Back Cover Replacement: шаг 3, изображение 2 из 2
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Back Cover Replacement: шаг 4, изображение 1 из 2 Canon PowerShot SX120 IS Back Cover Replacement: шаг 4, изображение 2 из 2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Back Cover Replacement: шаг 5, изображение 1 из 1
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Back Cover Replacement: шаг 6, изображение 1 из 3 Canon PowerShot SX120 IS Back Cover Replacement: шаг 6, изображение 2 из 3 Canon PowerShot SX120 IS Back Cover Replacement: шаг 6, изображение 3 из 3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Back Cover Replacement: шаг 7, изображение 1 из 1
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
Заключение
2 участников успешно повторили данное руководство.
Maria
Участник с: 03/13/14
875 Репутация
1 руководство автора
Команда
New Mexico State, Team 1-3, Easley Spring 2014 Участник New Mexico State, Team 1-3, Easley Spring 2014
NMSU-EASLEY-S14S1G3
4 членов
Автор 4 руководств
Один комментарий
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
Frederick Czarnik - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 1,702
