Введение
First remove the back casing and control dial before attempting to remove buttons.
Выберете то, что вам нужно
Turning the camera so the screen is facing you.
Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
Open the DC IN A/V OUT DIGITAL cover.
Turn the camera with the lens facing down.
Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
Carefully put pressure on the opening tool so the cover can gradually open.
Slowly slide the opening tool along the gap and around the edge of the camera.
Carefully remove the pin underneath the dial using a pair of tweezers and set it aside.
Use a pair of tweezers to remove the old control dial and set the new control in the same place.
Once casing and control dial have been removed, you will begin removing silicone button pad.
Use tweezers to grip the edge of the silicone pad and begin lifting upward.
Once pad is separated from camera, use tweezers to grip button(s) that need to be removed, and lift until it has been separated completely from the pad.
