Введение
This guide walks you through how to replace a format wheel on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
Выберете то, что вам нужно
Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the back of the camera.
Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the side of the camera.
Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the bottom of the camera.
Use your hands to gently separate the back plate from the camera.
Slowly pull off the camera plate until it fully detaches from the camera.
Use your hands to gently separate the front plate from the camera.
Congratulations, you have successfully replaced your format wheel. To reassemble your device, follow these instructions in reverse order.
