Введение
Refer to this guide if you are having trouble focusing your Canon PowerShot SX280 HS. The AF assist lamp helps to focus the camera when in dimly lit areas, and this guide instructs you on how to replace it. The Essential Electronics Toolkit is required for this replacement.
Выберете то, что вам нужно
Remove the outer covering from the camera.
Remove the tabs from the motherboard.
Remove the tabs which will slide out with a chip. The chip is attached to the GPS.
