Введение
Does your screen flicker or simply not turn on? Replacing the LCD screen may solve the problem.
Выберете то, что вам нужно
Using your fingers, slide the battery compartment door to the right until it unlocks.
Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
Pull back the rubber facing to access the A/V and HDMI output compartment.
Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
