Введение
If your camera is not quite functioning correctly, it may be the processor has become faulty. We'll show you how to fix it.
Выберете то, что вам нужно
To remove the battery, locate the battery cover on the bottom of the camera.
Using your thumb, press down on the cover and slide it outwards.
Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
Use an opening tool to gently remove the power and shutter button assembly from the frame.
Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
Lift the LCD screen ZIF connector tab and remove the ribbon cable.
Detach the no-fuss connector.
Lift the screen from its holder.
Use a #000 Phillips screwdriver to remove the three 4mm screws that hold the assembly to the frame.
Remove the 4 remaining 4mm screws in the frame with a Phillips #000 screwdriver.
Gently remove the frame. (Make sure to have a firm hold on the rest of the camera at this point)
Один комментарий
Note re Step 13: the cable has a 'click' type lock (you can see it as a narrow brown plastic strip on Step 12 and 13 pics). This lock can just about be disengaged with care before extracting the cable, I didn't, I just released it with tweezers as shown, and it didn't cause a problem. However, reversing Step 11 is very very difficult and you MUST have the click lock thing open before you begin (it's easy to see and understand when the switch plate is off , look at Step 12). You can then (just about!) re-insert the cable, and through a hole in the metal frame, just kind of below where the shutter button lies, flip the lock back down to hold the cable (use a tiny screwdriver or similar). It took me an hour to get the cable back in...so good luck with this part!
