Введение
If you have broken the back cover to your camera or it is worn out this guide will show you how to replace it.
Выберете то, что вам нужно
Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
2 участников успешно повторили данное руководство.
