Введение
This guide will show you how to replace a broken or malfunctioning LCD display.
Выберете то, что вам нужно
Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
Use a JIS 000 screwdriver and remove the 3.0mm screw from the bottom housing.
Use tweezers to pull out the circled brown flat flexible wire from its connection.
Use a spudger to reach under the connecting wire.
Gently slide the spudger under the wire and lift the wire off the connection.
Еще один человек закончил это руководство.
