Введение
This guide will show you how to replace the motherboard in your computer if it is broken or malfunctioning. In this guide you will be dealing with fragile parts, to avoid further damage handle all parts with care.
Выберете то, что вам нужно
Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
Remove the shutter button located at the top left of the camera.
This will expose the screws that need to be removed.
Using a JIS 000 screwdriver, remove the 1.2mm screw at the top left of the motherboard.
Remove the last 1.2mm screw to pull out the motherboard.
The motherboard should freely separate from the housing.
