Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
You will have to get into the inside of the camera before removing the flash bulb is possible. Some soldering may be required to completely remove the flash unit from the camera.
Запчасти
Детали не указаны.
  1. Unlock the battery cover, while swinging  the cover outward to open it. Unlock the battery cover, while swinging  the cover outward to open it.
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Turn the camera over and allow the batteries to fall out.
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Remove the three 3 mm screws that attach the side panel to the body of the camera. Using your fingernails, pull the side panel outward to remove it. Remove the two remaining 2 mm screws that attach to the frame of the camera.
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Open the battery cover.
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  7. Open the digital A/V DC terminal cover. Remove the three 4 mm screws.
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  8. Grip the sides of the top cover and gently lift the cover until it detaches from the camera.
    • Grip the sides of the top cover and gently lift the cover until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  9. Open the battery cover. With the camera upside down, pull the  front case's side that is closest to you, in an  outward movement.
    • With the camera upside down, pull the front case's side that is closest to you, in an outward movement.
    • Apply some force, but pull it gently to prevent damage.
  10. Open the memory card slot cover. Remove the 3 mm screw that sits near the bottom of the case.
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  11. Flip the LCD screen all the way open. Grip both sides of the back case's top and gently pull it, in an outward movement, until the case detaches. Grip both sides of the back case's top and gently pull it, in an outward movement, until the case detaches.
    • Flip the LCD screen all the way open.
    • Grip both sides of the back case's top and gently pull it, in an outward movement, until the case detaches.
  12. Remove the 3 mm screw that holds the flash unit to the camera.
    • Remove the 3 mm screw that holds the flash unit to the camera.
  13. Using your forefinger and thumb, pull the flash unit upward, and out of the camera.
    • Using your forefinger and thumb, pull the flash unit upward, and out of the camera.
    • The flash unit capacitor may cause electric shocks. Do not touch both metallic ends of the capacitor simultaneously.
  14. Remove the 3 mm screw that sits on the back of the circuit board.
    • Remove the 3 mm screw that sits on the back of the circuit board.
  15. Unsolder the white, yellow, brown, and green wires at their soldering points.
    • Unsolder the white, yellow, brown, and green wires at their soldering points.
    • Remove and replace the flash assembly.
Заключение
Matthew Ramirez
Участник с: 20.01.2011
625 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 11-26, Maness Winter 2011 Участник Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
3 членов
Автор 5 руководств
Один комментарий
Where is loccated the CMOS Battery?
Belkis Orozco - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 5,009
