Введение
This guide will help you remove and replace your Canon Powershot A610 speaker, bringing back the ability for your camera to use the Sound Memo Function and shutter effects again as long as that was the only underlying issue.
Before beginning this repair, power off the camera, disconnect from the power adapter, and remove the battery.
This repair requires soldering so if you're not experienced, ask for assistance and take a look at the How to Solder and Desolder Connections for more information.
Выберете то, что вам нужно
Remove the three screws attaching the side panel using a Phillips #00 screwdriver.
Remove the side paneling from the camera.
Remove the two remaining screws attached to the frame of the camera.
Open the "DIGITAL AV OUT" door on the camera.
Remove the three screws.
Remove the door from the camera.
Gripping the sides of the top cover, gently pull apart the top cover from the camera.
Using an opening tool, push the black attachment away from the white connection piece to detach the connector ribbon.
Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
Use a bit of force as the speaker is glued into the top casing.
