Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the three screws attaching the side panel using a Phillips #00 screwdriver.
Remove the side paneling from the camera.
Remove the two remaining screws attached to the frame of the camera.
Open the battery cover.
Remove the four screws inside.
Close the battery cover.
Open the "DIGITAL AV OUT" door on the camera.
Remove the three screws.
Remove the door from the camera.
Gripping the sides of the top cover, gently pull apart the top cover from the camera.
Gently pull apart the front cover from the camera.
Using an opening tool, push the black attachment away from the white connection piece to detach the connector ribbon.
Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
Use a bit of force as the speaker is glued into the top casing.
Desolder the speaker at the two solder points and reattach the new speaker.
