Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide explains the location of exterior screws and the process to remove the rear panel.
Запчасти
Детали не указаны.
  1. Unscrew the three small screws on the bottom of the camera.
    • Unscrew the three small screws on the bottom of the camera.
    • Remove the wrist strap.
  2. Remove the screw in the CF compartment.
    • Remove the screw in the CF compartment.
  3. Open the rubber Digital AV Out compartment flap. Pry the battery with the IFIXIT opening tool. Carefully pull out the battery with two fingers.
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with the IFIXIT opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible.
  4. Starting from the bottom, carefully pull the casing off. The casing will now pivot at the top.
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  5. The interior of the camera should look like this.
    • The interior of the camera should look like this.
Заключение
Shalan Ertis
Участник с: 26.01.2010
65 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 14-40, Regan Winter 2010 Участник Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
5 членов
Автор 15 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 3,055
