Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide explains the location of exterior screws and the process to remove the rear panel.
Выберете то, что вам нужно
Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
Remove the wrist strap.
Open the rubber Digital AV Out compartment flap.
Pry the battery with the IFIXIT opening tool.
Carefully pull out the battery with two fingers.
Remove the two screws that are now visible with a Phillips #00 screwdriver.
Starting from the bottom, carefully pull the casing off.
The casing will now pivot at the top.
There are three catches that hold the back casing to the body.
