Введение
This guide will assist in replacing the motherboard for the Canon Powershot A720 IS. Due to the difficulty of this project, it is important to be sure that the motherboard is what needs to be replaced. Improperly handling the motherboard can potentially result in permanent damage to the camera or the motherboard. To reduce the risk, an anti-static bracelet should be used. This project does require the use of a soldering iron; therefore, make sure you know how to safely and properly solder.
Be mindful to not touch the surface of the board. The oils in your hands can be harmful to the motherboard. If you need to adjust the camera, make sure to hold on to the case.
Выберете то, что вам нужно
Push the grey rubber battery lock on the bottom of the camera to open the battery compartment.
Remove the batteries and set them aside.
Place the camera down so that the lens is facing up.
Remove the single 4 mm screw from inside the battery door using a Phillips #00 screwdriver.
Remove the door from the camera.
Remove the six 4 mm screws on the sides and bottom of the camera using a Phillips #00 screwdriver.
Remove the two 3 mm screws below the LCD screen mount using a Phillips #00 screwdriver.
Remove the top 4 mm screw using a Phillips #00 screwdriver.
Carefully lift and turn over the LCD screen so that you are able to access the motherboard.
Carefully disconnect the LCD screen ribbon cable from its ZIF connector with your thumb and index finger.
Use the soldering iron to separate the black and red power wires from the motherboard.
Remove the 3 mm screw that is between the circuit boards using a Phillips #00 screwdriver.
Remove the three 3.5 mm screws that are on the button circuit board using a Phillips #00 screwdriver.
Use the spudger to carefully unclip both wires from underneath the shutter button and the dial housing unit.
Turn the camera over and remove the 4.5 mm screw that is next to the settings dial using a Phillips #00 screwdriver.
Remove the 3 mm screw from the metal frame to detach the battery housing unit using a Phillips #00 screwdriver.
Use the plastic opening tool to separate the user button circuit board from the shutter button and settings dial housing unit.
Carefully disconnect the ribbon cable that is attached to the user buttons circuit board from the ZIF connector that is attached to the motherboard with your thumb and index finger. Get as close to the ZIF connector as possible without touching the motherboard.
Remove the user button circuit board.
After all of the ribbons have been disconnected, gently lift the motherboard to expose the ribbon cable that connects the motherboard to the lens.
Use the spudger to remove the the ribbon cable attached to the motherboard. Be sure to alternate pressure to both sides of ribbon cable to evenly remove.
With the lens facing up, remove the 3 mm screw that attaches the bottom of the battery housing unit to the lens using a Phillips #00 screwdriver.
Turn the camera over so the bottom is now facing up.
Remove the 3 mm screw to disassemble the battery housing unit from the camera using a Phillips #00 screwdriver.
Remove the metal frame from battery housing unit.
Separate the lens from the body, being careful to keep all of the parts together. Set aside in a safe location.
Use the tweezers to remove the red tape and rubber strap to begin removing the wires from the plastic hooks.
Use the soldering iron to remove the red and black wires from the battery contacts.
Use the soldering iron to melt the wire contact points and detach the motherboard.
2 участников успешно повторили данное руководство.
