Canon Powershot ELPH 100 HS Outer Case Replacement
Выберете то, что вам нужно
  1. Canon Powershot ELPH 100 HS Outer Case Replacement, Outer Case: шаг 1, изображение 1 из 1
    • Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
    • Keep track of all the screws that are being taken out from the outer case.
    • The display screen of the camera should be facing towards you.
  2. Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 2, изображение 1 из 1
    • Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
    • Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
  3. Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 3, изображение 1 из 2 Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 3, изображение 2 из 2
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  4. Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 4, изображение 1 из 2 Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 4, изображение 2 из 2
    • Use the Philips #00 screwdriver to pry open the charging port cover.
    • Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
    • Remove both 3.1 mm screws using the Phillips #00 screwdriver.
    • The image still shows the screw from step 3 in place.
  5. Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 5, изображение 1 из 2 Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 5, изображение 2 из 2
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
    • Carefully go around all of the edges until the cover is released.
  6. Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 6, изображение 1 из 1
    • Once the entire front cover has been released carefully pull it off.
    • Be careful not to break the tabs that hold it in place.
  7. Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 7, изображение 1 из 3 Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 7, изображение 2 из 3 Canon Powershot ELPH 100 HS Outer Case Replacement: шаг 7, изображение 3 из 3
    • Just like Step 4-6 , carefully use the Spudger to remove the back cover.
    • Go along all the borders of the back cover so that it releases from the camera safely.
    • Be careful not to break the tabs.
Заключение
6 участников успешно повторили данное руководство.
Jacob
Участник с: 03/17/15
570 Репутация
Автор 3 руководств
Команда
Michigan Tech, Team 1-10, Lauer Spring 2015 Участник Michigan Tech, Team 1-10, Lauer Spring 2015
MTU-LAUER-S15S1G10
2 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 23
За всё время: 1,595
