Введение
Hello everyone, this step by step guide will hep you put a new outer case replacement on your Canon Powershot ELPH 100 HS!
Выберете то, что вам нужно
Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
Use the Philips #00 screwdriver to pry open the charging port cover.
Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
Remove both 3.1 mm screws using the Phillips #00 screwdriver.
Turn the camera so the bottom is once again facing up.
With the battery door still open, use a spudger to remove the cover from the front of the camera.
6 участников успешно повторили данное руководство.
